1989 honda civic "the bucket"
Show of your 4th gen Civic!
javieref9
Post by javieref9 »
this was the frist day i picket up my $500 civic also know as bucket...started as stock civic with d15b2 duel point fuel injection...
did a multi fuel injection conversion drop a b16a with 1990 integra tranny which is one of the wrost tranny ever because its long gears! but was the only tranny that had and i was in budget.....
upgrade
skunk2 manifold
74mm skunk2 throttle body
ctr pulley
xtd 8lb flywheel with stage 1 clutch
stock headers
stock cat
stock exhaust cut as a straight pipe
welbro 255 fuel pump...stock fuel pump was leaning out past 6k..ecu chipped with base map by nick cage tuning....local tuner lol
pulled b16a to give it a rebuild after racing the shit out it...
but in mean while i drop a ls/vtec i was build for it
spec on ls/vtec ....the block been decked and bored over 84mm.....its running 10.6:1 piston there off brand piston..the brand is ycp.....got supertech ring and supertech block guard...eagle h beam rods with stock gsr head never ran obx itbs...end up using gsr skunk2 replica manifold and 74mm throttle body :'(
