My First Civic! Hopefully...
CHANCELLOR12
Post by CHANCELLOR12 »
Hello everyone, i am new to the forum and am looking at buying a 91 Hatch. The car has lots of work done to it and i want to daily drive it. I am just wondering how reliable it will be, i know it depends on how well the work was done. Im going to look at it later today. Here is the list of everything done, let me know if anythings suspiscious or concerning. Thanks
-Engine
Jdm b18c gsr (fresh rebuild only break in time on it )
Arp head studs
Cometic headgasket
Super tech titanium retainers , dual valve springs
3 angle valve grind , new valve seals
Port job , decked block and head
Skunk 2 intake , performance products 68mm throttle body
Aem alloy black fuel rail , acura rdx injectors. Dpfi to mpfi brand new engine harness. Aem cam gears ,greddy timing belt .
Skunk 2 pro 2 race cams
Skunk 2 lma springs
Thermal intake gasket . Toda b rep header
B16b pistons (new ) alc Race bearings
B16b single drive crank pulley
Custom braided fuel line
Silicone rad hoses , mishimoto alloy rad , slim electric fan
Hasport polish alloy mounts , hasport cable to hydro conversion
K tuned trac bar / rad support
B&m Ajd fuel reg / guage
Powder coated rear t bracket ( black )
- Transmission
S80 jdm gsr LSD
4.4 final drive
Exedy stage 2 clutch
Toda lightweight flywheel
Fresh oem honda manual trans fluid
New b series linkage and poly bushings
Short shifter , spoon shift knob , shifter extension
-suspension / braking
Eg omni power fully body coilovers
New Polly bushings everywhere
Skunk 2 front camber upper arms
Skunk 2 rear camber upper arms
Skunk 2 rear lower gold alloy arms
Spc rear toe arms ( shepherical joints )
Rear disc conversion from ek sir
New rear e brake cables , callipers , hawk pads . Ebc rotors
Front new spoon brake pads , ebc rotors
Super blue brake fluid
Hard race rear trailing arm bushings
Rear trailing arms powder coated black
Interior / exterior
Oem black bumpers front and rear
Vw front lip
Clear front corner lights
New front fenders , fresh paint white
Fresh paint on front under headlight filler
Fresh paint on rear under tail light filler
New oem window molding
Oem sir ef9 rear wing ( working led 3rd brake light )
Oem sir ef9 rear garnish
Auto power 4 point cage
Sparco fighter fibreglass seat on sliders ,takada 4 point harness (new)
Si passenger seat
Jdm type r dc guage cluster
Nardi wood wheel
Black/white checkered headliner
Oem passenger mirror block off plate
Oem honda hood bra
-Wheels and tires
Custom made centreline alloys
Front size 175/55/15 contiprocontact 15x9 +20 offset
Rear size 155/60/15 kumho 15x9 - 15 offset
Re: My First Civic! Hopefully...
Welcome! Sounds cool, at a quick glance nothing jumps out(at me at least) :)
CHANCELLOR12
Thanks! The car is slammed and stanced right now with a lot of negative camber. I live in ontario canada and the snow gets really bad here a few times a year so i plan on raising the coilovers a couple inches and getting snow tires and black steelies.
I dont know the exact specs of the camber but it looks to be about -6 in the back and around -4 in the front but i could be wrong. Is it okay to keep the camber as it is and raise the car a bit with snow tires?
CHANCELLOR12
Wow, i checked out the car. It was sweet! But theres no way i would be able to use it as a daily, almost fully gutted, and the rear quarter panels were a little rough and already fixed a few times. The owner was a great guy and understood that the cars not for everyone and is built for the track. If anyone in the southern ontario region is looking for an EF here one to check out.
http://m.kijiji.ca/cars-trucks/oakville ... 0979250224
Jon Widmer
Post by Jon Widmer »
I wouldn't mess with it for a daily driver either. I'm glad you passed up on it.
It sounded pretty hooked up though!
CHANCELLOR12
There are no other EF's for sale around me that arent completely rusted out. Im gonna have to look for an EG or EK, a few years newer so less rust and way easier to find.
Theres an EK with a B16a, bolt ons, i/h/e, strut bars and lowering springs.
And an EG with a stock D series with intake and exhaust, but everything else is done, coilovers, control arms, recaro seats, 4 wheel discs, camber kit etc etc etc.
But i think i really want a B swapped hatch and figure i can do the other stuff myself.
Btw all of these cars are aound the same price, ranges from $3700-4750. Is this a reasonable price for a modded Honda? They all seem like pretty good deals if theyre in decent shape.
No way that hatch you linked to has seen a minute of track time with that hellafail suspension...
CHANCELLOR12
When i went to look at it he had some te37s on it with brand new tires, not hellaflushed but still dropped a bit.
Raised up it could. As it sits in the pictures with the wheels/tires under it.. no
I'm not a fan of hellaflush as you can probably tell. :D
CHANCELLOR12
Well, i bought a 97 Civic Cx hatch. Im picking it up next weekend. I probly wont be on these forums because i have the wrong car lol. The car has a b16a with an aem fuel rail, blox throttle body, p72 chipped ecu, short ram intake, megan racing headers, 5zegin 2.5" exhaust, no cat, REworks strut bar, unknown c-pillar bar, skunk 2 lowering springs, og axis rims and HID's. It's got a little bit of rust around the rear wheel wells, but underneath is spotless, the car is not hacked up at all as the owner is a mechanic at a honda dealer and he said he "tried to keep everything as oem as possible".
My plans for the car are: Beaks bar, rear LCA's, short shifter, spoon spoiler, the car came with some skunk2 low profile valve cover washers that i might put on. And i was thinking of picking up some rear quarters and fixing rust myself or having a body shop do it.
I drove the car around the block, but i was in a city ive never been in before, so the owner hopped in and took me to the highway where he took it up to like 10k rpm. Ive never owned a honda before let alone a modded one, is it okay to rev that high occasionally? What should i be redlining at?
I've also watched videos on the valve cover washers, it seems easy but is there any risk in taking off the valve cover? I dont wannna mess it up.
Sorry im still a noob
10k sounds a bit much. If slightly upgraded it can take it. Normally it's a good few thousand below that.
