FS: MPFI parts for DPFI to MPFI swap
Post your For Sale threads here
sstupid
Post by sstupid »
Hi, guys. I bought the MPFI intake tube/airbox, the intake manifold with all sensors/injectors, wiring, the wiring harness from the fuse box out to the motor, the throttle cable, and the resistor box off a '91 Civic EX sedan. I got all geared up to do the swap and just lost interest. This was going to be a hobby thing but I decided I would rather have air conditioning. All the stuff is pretty heavy, so shipping won't be cheap, but I thought I would put it on here, just in case. I also have a PM6 ECU, but it's from a 4WD auto wagovan. I can't find any information about whether or not it will work but consensus is that it should, because the wagovan had a separate module for the tranny. I put a pic of the manifold on here. You will get everything you see except some of the corroded hoses that I threw away. Injectors are obd0. Will not part out. Thanks for looking.
$170 plus shipping. Includes the PM6. If you want to buy it without that, it's $150 plus shipping.
sstupid
Re: FS: MPFI parts for DPFI to MPFI swap
Post by sstupid »
Sold!
