WTB 88-91 Civic/CRX SI rear Sway Bar Assembly
Post your Want to Buy threads here
Zcwagon
Post by Zcwagon »
Hey
Want to upgrade rear end of my 91 DX.
Need a complete rear sway bar assembly should be 15mm thick complete with bar, bushing clamps, bushings, D brackets, end links and hardware. Could use the rear lower control arms with end link connection but I'll take whatever you have.
I'm sure some of you have after market bars now and these laying around please hit me up.
I need this for my 24 Lemons car!!!!!!
Texting me is best.
I'm in Phoenix area.
Thanks
Jeff
480-678-5663
zcwagon Posts: 13Joined: 23 Nov 2007Location: Fountain Hills, AZ
Zcwagon
Re: WTB 88-91 Civic/CRX SI rear Sway Bar Assembly
Post by Zcwagon »
got one thanks
still need rear lower control arms with sway bar connecting points for the 91 DX. I understand arms from 89, 90 or 91 will work as long as SI (88 was different style shock mount).
Also understand integra 94-2000 will work as they are the same and all had rear sway bars
Zcwagon wrote: I understand arms from 89, 90 or 91 will work as long as SI (88 was different style shock mount )
You are correct . As far as the integra arms I do not know if they would change your suspension geometry angles.
Zcwagon
Post by Zcwagon »
I found a set of lower rear control arms and I CRX so I don't need anything thanks for all your help
