89 Si hatch won't start
M-Benz
Post by M-Benz »
Hello all ,
I picked up this car on this morning and it ran fine from the place I bought to my house but when I tried to start again so that I can go to the gas station ...it die on me . The engine won't crank over and the car won't start. Note : all dash lights ( no error code ) , radio are work fine . Me and my friend already tried afew things like ignition switch , we did replaced the starter motor and the main relay is fine . What could it be ? Can anyone helps ? The last thing that I can think of is the starting solenoid ? I mean I didn't hear any strong click/clank in the engine area . Thoughts ???
Thanks in advance,
Andy
Re: 89 Si hatch won't start
It could be the starter solenoid if everything else seems to be fine.
M-Benz
Post by M-Benz »
Sandman,
I went to the autozone earlier and asked for the starter solenoid because i dont know what it looks like but it came out that solenoid is attached to the starter motor (am i right on this ?) which i replaced that already so what else could it be ? is there such thing as transmission solenoid ? Also the guy at the autozone says it could be the Neutral Safety switch ? Im about to lose all my hairs because i keep scratching it ..what the heck is going on with this car ? :angryfire: One more question, how about the clutch ? if the clutch is bad can the engine start ? This is my first car with the standard transmission ...dont know the whole lot about it. Can anyone please help ? Just cant believe it happened on th same day that i bought the car :banghead:
Edit: Does this car have the neutral safety switch ? and do you guys think that is the problem or any switch that connect to the clutch ? If so, where do i get that Neutral safety switch ?
M-Benz
Post by M-Benz »
Just for everyone know if you ever get that sympton ...it is the "CLUTCH PEDAL SWITCH" . Finally finallly ;D
how did you find out?
M-Benz
Post by M-Benz »
Very simple and just like anyone else ..I tested each unit and try to eliminate one by one . One thing that really helps me is I searched around ... Just google it :)
lol trust me i would if i need to but glad car starting and is in good shape.
M-Benz
Post by M-Benz »
Hahaha okie . The mods begin now....
