Head Gasket Replacement questions
Mac Listo
Post by Mac Listo »
My car was overheating while stuck in traffic but when I started driving the temp went back to normal. Popped my near full radiator cap off and found oil streaks in it. Topped it off and started the car and coolant jumped out.
Rather than just doing a head gasket replacement, what other things should I swap out while im in there? I was thinking ARP Studs, some sort of performance head gasket rather than an O'rielleys or autozone one, maybe do my timing belt and all the stuff attached to that while im in there. Anybody have any links to good replacement parts for my ride?
Engine is a B16a JDM OBD-1
Re: Head Gasket Replacement questions
I don't know what brand of timing manifacturers you have available, but Gates is who makes the OEM timing belts and they even sell upgrade ones. I suggest you go with that. Replace the water pump and tensioner as well. While the head is off, replace the valve seals as well as the sparkplug seals and valve cover seal.
po18guy
Post by po18guy »
I would strongly advise that you have the cylinder head surfaced. They warp easily from overheating and the best gasket on earth cannot seal if the head is warped. Do it right. Do it once.
