Engine swap guide, FAQs and Index thread
HonduhDave
Re: Engine swap guide, FAQs and Index thread
Post by HonduhDave »
aha, I was trying to figure out what rad hoses to buy to replace the old/cracked ones I have currently and now I have my answer! ;D
Reorganized index, and plenty of new links added to engine and trans area. Noobs are encouraged to read everything here until your eyes bleed :happy6: .
Chiny
Post by Chiny »
The DIY: Reupholstering/repairing your front seats (getting rid of the outer edge wear) is no longer a good link and the integra dc center console swap, both of those are not good either :(
fiernaq
Post by fiernaq »
The "ZC Swap Guide" link under D-Series Engines doesn't work right now.
Fixed and new links added.
thx
jac1989civ
Post by jac1989civ »
I have been doing a lot of thinking lately and I think I have come to the conclusion that I want to do an engine swap on my civic. I have no idea on what engine I want to use yet though. I've been told having a rebuilt one would be cheaper than getting another one.With all that's out there I can't help but wonder how far do I have to go to have it swapped? I'm not even sure if mine has an ecu in it. So if I had it swapped out and the engine I had swapped in had an ecu, what else would I have to change? A lot of engines have been suggested to me, but I really don't have a clue of where to start :/
lakshmi
Post by lakshmi »
Hi everybody,
engine swap imo is highly dangerous. it wuld create a lots of pblm
nuno_p
Post by nuno_p »
CIVIC 88-91 manuals links are down.
Can someone post them again?
Thanks in advance.
Astar11
Post by Astar11 »
A little confused about something if somebody could help me out. I have a 1990 civic hatch with a b18a1 from a 1992 tegra. I'm not sure if I need to modify the engine harness or if I can use a stock harness from the b18 I know this thread sais stock harness works but other people told me it won't hook into the main harness for the ecu. If somebody could clear this up for me if appreciate it thanks
cjohnsontech
Post by cjohnsontech »
Stock harness and ECU from the donor vehicle. ECU and engine have to match (with only a few exceptions)
Trying to keep my page current with worthwhile information. PM me if you want me to add something:
http://www.cjohnsontech.com
bigmoneyjizo420
Post by bigmoneyjizo420 »
Help please!!!
I removed the engine from my 91 civic hatch about,2 years ago now
I'm putting new one in ... it's a d15b2 with d16z6 head I need to know
What or where the plugs on my engine harness hookup at ??
Thanks for.any. help
Search the forum for the "ef service manual. It shoulf have what you need. ;)
I'd look it up for you, but I'm on my phone so I rly can't.
kade89x
Post by kade89x »
Im new here and I couldnt find a clear answer.. i just picked up an engine and transmission for 150 bucks pretty much just for the manual transmission. i have a 1989 civic sedan with the stupid 4spd auto. anyway the only identifying number says d15a 3-1002805. try as i might i cant find jack on a d15a, except that it might be out of 88-91 dx... oh and its pgm-fi and air con.. any help would be awesome, thanks. id add a couple pics but cant seem to figure out how..
D15A3
Found in:
1985–1987 Honda CRX Si and 1987 Civic Si (AU/NZ)
1985–1987 Honda Civic 1.5i (Europe)
1984–1987 Honda CRX 1.5i (Europe)
Displacement : 1,488 cc (90.8 cu in)
Bore and Stroke : 74 mm × 86.5 mm (2.91 in × 3.41 in)
Compression : 8.7:1
Power : 91 hp (68 kW, 92 ps) at 5,500 rpm
Power : 99 hp (74 kW, 100 ps) at 5,750 rpm (Europe)
Torque : 93 lb·ft (12.9 kg/m, 126 Nm) at 4,500 rpm
Valvetrain : SOHC (12 valves, three per cylinder )
Fuel Control : PGM-FI2
kade89x
Post by kade89x »
damn, ok, thanks man
