Page 5 of 7
DPFI to MPFI Conversion
PostPosted: Thu Jan 08, 2009 6:55 am
by 90hatch268
"r4BBiT" wrote:(but i got 5 finger discount on ECU if u know wat i mean ;))
yep, saw it on a porn site :shock:
PostPosted: Fri Jan 09, 2009 12:52 am
by r4BBiT
LOL
PostPosted: Fri Jan 09, 2009 4:45 am
by Dave
im swapping to mpfi becaus im switching over to either a ZC or d16z6, will i need to change the ecu t a pm7/p28 for this to work or could i just use the stock ecu
Re: DPFI to MPFI Conversion
PostPosted: Mon Apr 13, 2009 1:42 am
by cougar289
Dave wrote:im swapping to mpfi  becaus im switching over to either a ZC or d16z6, will i need to change the ecu t a pm7/p28 for this to work or could i just use the stock ecu
You will need an ecu that is capable of running MPFI. P28 would be great for a D16Z6, PM7 for a ZC.
PostPosted: Fri Jun 05, 2009 10:51 pm
by MBHBGUY
does anyone have a link to a site for diy wiring for a b series harness finally have my b series harness obd o to 1 jumper and my b18 block lookin for my head and all the other goodies but want to see what i have to do to incorporate the b series harness to the dx wiring without replacing every harness throughout the entire car HELP
PostPosted: Thu Jun 11, 2009 7:36 am
by el_jelly
put that question in the technical area, this sticky is just for dpfi to mpfi stuff.
PostPosted: Thu Jul 30, 2009 11:42 pm
by EFnBOOST
Just did this conversion on my hatch, in order to be able to put my turbo on.
Want too hard if you have some wiring expirience and some patience.
If i could make one reccomendation it would be to get a EF Si IM, instead of a EG IM or any other IM off of another model honda. EF Si will be the easiest and most direct switch.
Good luck :)
PostPosted: Sun Aug 23, 2009 11:31 pm
by Tizzle
So where do you wire in the harness for the fast idle solenoid valve? I have the plug and all that jazz I just need to know where to run the wires from.
PostPosted: Mon Aug 24, 2009 1:16 am
by r4BBiT
one wire is ground and the other one was blue i think and it was one of the wires you cut at ecu for mpfi swap, i i thinks its b2, good luck ;)
PostPosted: Thu Aug 27, 2009 8:33 am
by el_jelly
More dpfi-mpfi articles:
PostPosted: Fri Nov 06, 2009 11:16 pm
by el_jelly
And another one with pics and diagrams:
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
PostPosted: Thu Feb 25, 2010 8:11 am
by joehein
this is the guide i'm gonna go by: http://enginemaniac.blogspot.com/2009/1 ... -swap.html
seems pretty straight forward
PostPosted: Fri Feb 26, 2010 3:22 pm
by el_jelly
I remember seeing that blog before...
PostPosted: Fri Feb 26, 2010 6:26 pm
by 91EFbluehatch
I am also going to do this swap for my engine before i go with VTEC. But it has been hard finding an actual MPFI intake system.
PostPosted: Thu Apr 01, 2010 9:35 pm
by hatch602
I have a 91 hatch Dpfi automatic. I replaced b2 motor with ZC 1.6. Now I want to do the conversion to MPFI. What ECU should I be looking for that will work with my AT set up. Thanks in advance for any input.
