Best Fit Door Speaker Upgrade
Postby onyx2002 » Thu Sep 13, 2007 4:05 am
Guys,
Gonna upgrade Front Door Speakers on my 90 DX, I just wanted to know if these are indeed 5 1/2 inch speakers ( Pretty sure they are) and are there any brands/types in particular that fit better than others with minimal modification etc... Mine are still stock...I'm sure alot of you have done this.. Any insight from your install will be a great help :wink:
onyx2002
Postby RKelley » Thu Sep 13, 2007 3:22 pm
I have a 1991 dx sedan and I changed mine out years ago with Pioneer Premier Components. When you take the cover over the speakers off, you will see that there is a bracket that holds the speaker in the door. You will need to take the whole bracket out with the speaker. You have to do this so that you can cut the basket off the back of the bracket to make room for the new aftermarket speaker. I used a grinding wheel but you can use a hack saw or whatever you have handy that will cut plastic. The factories are cheap and slim. Your new speakers will most likely be much bigger depth wise, thus the reason you have to do this. They still sound great and don't affect the sound. Alpine also makes very decent speakers. I have been told that Alpine actually manufactures the sound systems for honda, not sure how true that is. I know for my wifes 2001 civic sedan alpine provides the brackets with speakers that go in the door, because the factory bracket won't work. Not sure if they do the same for the 88 to 91 civics. I hope this helps. A good place to check out car audio stuff for a cheap price is www.sonicelectronix.com. You will have to click on all other manufacturers in the left side bar to be able to pull up the alpine products.
RKelley
Postby RKelley » Thu Sep 13, 2007 3:26 pm
Oh, I also forgot. I think the door speakers are 5 1/4 not 5 1/2. You can check what size you need on www.crutchfield.com or www.metraonline.com :D
RKelley
Postby siR in progress » Thu Sep 13, 2007 8:13 pm
crutchfield is shit
Postby KevinT707 » Thu Sep 13, 2007 8:46 pm
All 4 speakers on the CRX are 6.5". Be careful what speakers you get though because the Pioneer 4-Way that I got were too thick so when I rolled my windows down it would hit the magnet of the speaker; the Infiniti 2-Ways I got after that didn't.
90 CRX - Panda, bottle fed forged LS/VTECH
I ♥ my Honda
KevinT707
Postby onyx2002 » Thu Sep 13, 2007 10:51 pm
OK, :idea: Good info Guys... Metra online is saying that the front and rear are both 6" speakers ?? also....before i peel the rear panels outta my hatch to check... is it true the wires are in there somewhere
for the optional rear pods as well??
onyx2002
Postby chezuki » Thu Sep 13, 2007 11:10 pm
yes, wires are already there.
chezuki
Postby onyx2002 » Fri Sep 14, 2007 2:40 am
Damn... people sure do want alot of $$$$ for those OEM rear speaker pods... Were they found only in Si model.???. a wrecker very close to me has a 91 special edition Dx.. i didn't notice if it had them.. but i did manage to scoop a clock from it for my DX.. what others had the rear pods??
onyx2002
Postby chezuki » Fri Sep 14, 2007 3:12 am
just the SI
chezuki
Postby Sempron Gamer » Mon Sep 24, 2007 12:31 am
Ummm, I've got an 90 Si and mine doesn't have rear speakers... :?
(Canadian Si though)
1990 Civic Si
Canada
Sempron Gamer
Postby RabidSnake » Sun Sep 30, 2007 1:18 am
"Sempron Gamer" wrote:Ummm, I've got an 90 Si and mine doesn't have rear speakers... :?
Yeah same. But a USDM SI.
RabidSnake
Postby chezuki » Sun Sep 30, 2007 5:40 am
Well, you should have. Image
chezuki
Postby JDMjay » Sun Sep 30, 2007 7:55 am
I bought a 90 dx hatch without rear speaker pods and a 91 dx with rear speaker pods. It probably was an option.
JDMjay
Postby freydaddy » Sun Sep 30, 2007 4:20 pm
my 91 DX didnt hake pods. so yeah was probably an opion for each car.
1991 D16A6 Mini-Me OBD1...TURBO
Postby Parnelly » Tue Oct 09, 2007 11:00 pm
"JDMjay" wrote:I bought a 90 dx hatch without rear speaker pods and a 91 dx with rear speaker pods. It probably was an option.
Does that make sense? I mean, i have a CX. CX NO options. A DX More Options. SE, Basically an SI with, more "options". Whats teh point in cx/dx/std/si if you could get all teh options in a std or what have you?
4G4Life
Parnelly
Next
Users browsing this forum: No registered users and 5 guests
