My car doesn´t start or has other problems: troubleshooting
Re: My car doesn´t start or has other problems: troubleshoot
Postby 91hatchligon » Wed Dec 02, 2015 9:55 pm
Sounds like either the ignition module or the coil.
Postby Mac Listo » Sat Dec 12, 2015 8:02 am
91hatchligon wrote:1.When you turn the key to the on position can you here the fuel pump prime the system? it a buzzing/humming noise from the rear.
2. Are you getting spark when its not starting? If not is could be the coil or the ignition module.
3. Dose it seem not start more often when hot?
4. Have you had it die while driving?
1. I hear it prime when it starts and works. When it doesnt work it doesnt prime. Sometimes when it primes it turns over and starts and the idle slowly falls until it stops (about a 4 second process)
2. Yes.
3. I havent noticed it if it does but am curious to know.
4. No.
Mac Listo
Postby 91hatchligon » Sun Dec 13, 2015 7:59 am
Sounds like the fuel pump from what you are describing.
Postby Mac Listo » Wed Jan 06, 2016 5:34 am
Fuel pump was replaced when this was happening with a 255lph Walbro.
Replaced:
Fuel Pump
ECU (p28 to a 072 both obd-1)
Distributor
Main Relay
Fuel Filter
From what I gather, there is no fuel pump relay or fuse for a 90 hatch. If there is, I am missing it if its not part of what the main relay does.
Mac Listo
Postby Mac Listo » Wed Jan 06, 2016 7:53 am
Never Mind. I dont know what that 4 blade relay is behind the hood release, but there is an even bigger relay in that area and I took it out and it smelt burnt. I am assuming THAT is my main relay...
Mac Listo
Postby caljank » Sat Feb 20, 2016 12:17 pm
Nice, summary of starting issues. I appreciate your time and effort.
caljank
Previous
