DPFI to MPFI Conversion
Postby 90hatch268 » Thu Jan 08, 2009 6:55 am
"r4BBiT" wrote:(but i got 5 finger discount on ECU if u know wat i mean ;))
yep, saw it on a porn site :shock:
90hatch268
Postby r4BBiT » Fri Jan 09, 2009 12:52 am
LOL
and many more :P
r4BBiT
Postby Dave » Fri Jan 09, 2009 4:45 am
im swapping to mpfi becaus im switching over to either a ZC or d16z6, will i need to change the ecu t a pm7/p28 for this to work or could i just use the stock ecu
Honda, the power of dreams.................. HONDA, the dream of power
Dave
Re: DPFI to MPFI Conversion
Postby cougar289 » Mon Apr 13, 2009 1:42 am
Dave wrote:im swapping to mpfi  becaus im switching over to either a ZC or d16z6, will i need to change the ecu t a pm7/p28 for this to work or could i just use the stock ecu
You will need an ecu that is capable of running MPFI. P28 would be great for a D16Z6, PM7 for a ZC.
cougar289
Postby MBHBGUY » Fri Jun 05, 2009 10:51 pm
does anyone have a link to a site for diy wiring for a b series harness finally have my b series harness obd o to 1 jumper and my b18 block lookin for my head and all the other goodies but want to see what i have to do to incorporate the b series harness to the dx wiring without replacing every harness throughout the entire car HELP
motor almost complete
tranny almost here b series s1
11:1 jdm pistons
eagle rods
stock crank
gsr oil pump
gsr intake fuel rail
b16 jdm head
aem cam gears
i smell a sleeper in construction
MBHBGUY
Postby el_jelly » Thu Jun 11, 2009 7:36 am
put that question in the technical area, this sticky is just for dpfi to mpfi stuff.
Postby EFnBOOST » Thu Jul 30, 2009 11:42 pm
Just did this conversion on my hatch, in order to be able to put my turbo on.
Want too hard if you have some wiring expirience and some patience.
If i could make one reccomendation it would be to get a EF Si IM, instead of a EG IM or any other IM off of another model honda. EF Si will be the easiest and most direct switch.
Good luck :)
EFnBOOST
Postby Tizzle » Sun Aug 23, 2009 11:31 pm
So where do you wire in the harness for the fast idle solenoid valve? I have the plug and all that jazz I just need to know where to run the wires from.
Tizzle
Postby r4BBiT » Mon Aug 24, 2009 1:16 am
one wire is ground and the other one was blue i think and it was one of the wires you cut at ecu for mpfi swap, i i thinks its b2, good luck ;)
r4BBiT
Postby el_jelly » Thu Aug 27, 2009 8:33 am
More dpfi-mpfi articles:
Postby el_jelly » Fri Nov 06, 2009 11:16 pm
And another one with pics and diagrams:
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
Postby joehein » Thu Feb 25, 2010 8:11 am
this is the guide i'm gonna go by: http://enginemaniac.blogspot.com/2009/1 ... -swap.html
seems pretty straight forward
joehein
Postby el_jelly » Fri Feb 26, 2010 3:22 pm
I remember seeing that blog before...
Postby 91EFbluehatch » Fri Feb 26, 2010 6:26 pm
I am also going to do this swap for my engine before i go with VTEC. But it has been hard finding an actual MPFI intake system.
91 CIVIC hatch. b16a2 in the works
91EFbluehatch
Postby hatch602 » Thu Apr 01, 2010 9:35 pm
I have a 91 hatch Dpfi automatic. I replaced b2 motor with ZC 1.6. Now I want to do the conversion to MPFI. What ECU should I be looking for that will work with my AT set up. Thanks in advance for any input.
hatch602
PreviousNext
Return to How-To's
Users browsing this forum: No registered users and 3 guests
