how to clean your sunroof drain tubes the easy way
for the past week my area was drenched with heavy rains over days timespan and this made me realize that my sunroof was leaking alot of water into my backseat foot area. so i realized that my drain tubes were badly clogged since my sunroof seems to have a good seal on it. so i startedoff by going to the trunk and pulling out the tubes an there will be a little point nipple like this
remove that little nipple and stick your air hose in there and blow the SOB out good an continue to clean it if still dirty.
do this for both sides since you have a total of four drain tubes, 2 for front 2 for back.
the next step i took a small plastic tube smaller than the cars tube, taped it to my air hose and slid the tube into the cars tube and aired out the tubes from back first then front last. to blow it out vice versa stick the tube into the sunroof when its open right on top of the rails an you should hear the air escaping through the back of the car. but just make sure your tubes are pointing out of the trunk. for the front the holes are on the front corner of the sunroof bracket in front. once again stick the tube in or on the hole an press away and done.
after than you can close the sunroof and pour water on top of the car to see if water is getting in a draining properly. water should come out right behind rear wheel or behind the front wheels in the wheel well.
and thas it your cars drain tubes are unclogged
theres more DYI on how to do this online but some people say to remove headliner...
THIS IS NOT NEEDED, I REPEAT NO NEED TO REMOVE HEADLINER.
hope this helps those with leaky sunroofs and even if they leak the water should roll down on the rails an into the drain tubes.
P.S i stole some of the pics from this link =p
http://honda-tech.com/showthread.php?t=2872372
but i did this myself but was too occupied to take pics but this DYI is pretty straightforward and self explanatory.
if any more help is needed or anyone is unsure feel free to ask me or a fellow member
- gtviper2178
- L5 - Built Motor
Re: how to clean your sunroof drain tubes the easy way
I was getting water in my front passenger seat and visor area.
My front drain tubes were all clear.
Both rears are completely clogged.
I just said f*ck it and removed that 35lb weight!
- Black R
- L1 - DPFI
This should be in the How to section.
IHeartMySTD wrote: We all know we like our women and cars with D's, not B's!!!!
el_jelly - L6 - Race Bred
el_jelly wrote:This should be in the How to section.
how do we make this into the "how to" section?
- gtviper2178
- L5 - Built Motor
it already is...
90hatch268 - Global Moderator
That is a good way to detect clogged drain tubes, but remember your blowing all that trash back up to the tracks. When you get another heavy rain all that trash will come back down, hopefully it will flow right out and not get clogged. Good tip!
- brent636r
- L2 - MPFI
lol thanks mod guys!!! but i stuck the air hose from the sunroof then the air traveled throughout the car and down out of the trunk where no dirt got into my car. blowing from trunk to sunroof isnt a very good idea because like you said all the tracks will get dirty and can fall into your interior as well... easiest way to do it is stick a small tube down o the back of the track towards the rear of the car and let it rip, so far yet NO leaks what so ever. you'l know when your clogs are backed up if water is splashing down on you while your driving.
- gtviper2178
- L5 - Built Motor
got great ideas on cleaning my drained tubes... thanks for sharing this mate!
- gregy
- Registered User
sorry on the late reply but your welcome mate!
- gtviper2178
- L5 - Built Motor
