Preparing for a minime swap, do I need the z6 cam cover?
Postby somedude88 » Tue Aug 28, 2012 2:30 am
I picked up a z6 p08-3 head for cheap for my swap, but it doesn't have the plastic bolt on piece on the side of the cam underneath the cam gear where the cam cover mounts to, I know there is sights on it to line up the ignition timing. Can I just use my d15b2 one or do I really need to get the one for the z6 somewhere?
Also can someone help me out with the z6 valvetrain torque sequences in a picture, I was going to take it all apart because the guy didn't have any cover on the head so dust (maybe grit} got in there and I need to clean it up good but looked and couldn't find one.
Thanks a bunch, Derek
somedude88
Re: Preparing for a minime swap, do I need the z6 cam cover?
Postby somedude88 » Sat Sep 01, 2012 5:10 am
Nobody knows?
somedude88
Postby el_jelly » Sun Sep 02, 2012 9:42 am
You will have to download the manual for that specs.
Postby somedude88 » Tue Sep 04, 2012 2:04 am
I obtained a 94 civic manual, now I just need to know about the cam cover :-(.
Does anybody know about that?
somedude88
Postby 2 Stroke Toy Chest » Tue Sep 04, 2012 10:05 am
i know i have some lying around , but cant recall if they are for a z6 or y8 .
i work a grave yard shift and my weekend is coming up tommorow , when i get back to work i can have a answer possibly a pic for you
Postby somedude88 » Sat Sep 08, 2012 7:23 am
That would be great. If I need one I would def be interested. I still have the one for my b2 I just need to know if I need a different one.
somedude88
Postby 2 Stroke Toy Chest » Sat Sep 08, 2012 10:41 am
sorry man me and the lady have been at it and the honda was in the hot seat as the culprit . Now that she is gone home and not trying to sell the car out from under me , i will be able to look into that for you
Postby Azweezey » Sat Sep 08, 2012 10:57 am
somedude88 wrote:I picked up a z6 p08-3 head for cheap for my swap, but it doesn't have the plastic bolt on piece on the side of the cam underneath the cam gear where the cam cover mounts to, I know there is sights on it to line up the ignition timing. Can I just use my d15b2 one or do I really need to get the one for the z6 somewhere?
They are different... I tried to put the D15b2 on my Z6 and it did not fit...I Went Ahead and took some pictures for you...
http://www.flickr.com/photos/azweezey/7954419582/sizes/l/in/photostream/
For the Z6 the Chilton guide says to do the timing with that mark specifically for the Z6, but if you line up the one on the cam that says up and the lines that line up with the head, plus the one on the crankshaft, it should be fine...but these are known to be zero tolerant to being off and can bend your valves if ur wrong :D :D :D ...
Azweezey
Postby somedude88 » Sun Sep 09, 2012 1:05 am
Actually my concern was the ignition timing because the sights are on the cam cover.
somedude88
Postby somedude88 » Sun Sep 09, 2012 1:06 am
I just realized... it's on the lower part of the cover -_- LOL but at any rate I do want the cover with the bolts and such because it would make me nervous to have my belt exposed. So what would you give it to me for shipped to 48071
somedude88
Postby freydaddy » Wed Sep 19, 2012 10:44 pm
fyi, it will only bend valves if it is 90 degrees out.
Postby somedude88 » Fri Sep 21, 2012 3:34 am
The lineup for TDC is on the bottom half of the timing belt cover I noticed. So I should be Ok if I keep the bottom half of the cover the b2 one.
somedude88
