CivicJdmB16a's Build #2 ***Ls Vtec***
civicjdmb16a
Post by civicjdmb16a »
Well heres the first picture of my new motor. An B18a which was sleeved with AEBS sleeves good for 55+psi, by Z10 motorsports in Neptune, NJ.
It also has a Z10 girdle for spinning that crank high up that rpm range :D
The head is a B16 head and is at CNC port for a full port and polish and full valvetrain from supertech thats good to 10,500rpm's.
My last motor had a issue when i lost a piston and it took out the sleeve and the head. Mostly due to a poor sleeve install, no-name pistons and some bad desisions on my behalf :cry: Because of a bad sleeve install i kept blowing headgaskets and the last time it failed the piston broke into a million peices.
So now on to bigger and better things :twisted:
KevinT707
Post by KevinT707 »
Looks nice and sturdy! 8)
90 CRX - Panda, bottle fed forged LS/VTECH
I ♥ my Honda
Post by siR in progress »
im thinking about sleeving a GSR block with aebs sleeves, how much did that cost if you dont mind.
SIR_Injected
Post by SIR_Injected »
i had to rebuild my b16 so im just going to do what i can with it like ITB's and what not
civicjdmb16a
"siR in progress" wrote:im thinking about sleeving a GSR block with aebs sleeves, how much did that cost if you dont mind.
Z10 was running a special on b16's and b18a/b's for sleeving and girdle for $799. They usally charge $1075 and $180 for the girdle
http://www.z10eng.com/catalog/product_info.php?products_id=54
SIR_Injected
whats the purpose for the girdle i know stock GSR's have it
civicjdmb16a
"SIR_Injected" wrote:whats the purpose for the girdle i know stock GSR's have it
It gives the bottom end more strength by joining three main caps, and allows you to turn high rpm's. Since im going to be spinning 10,000rpm's i felt it was a must. i dont know why the GSR was the only one to come with that. you think the type r would have had it too.
SIR_Injected
hmmm you would think eh ? i would understand b16 wouldnt have it untill the 3rd gen b16a around the same time as the GSR... the type R should come with it too... i would buy one for my b16 just to have one thanks for the info... i figured it was there for more strength i just wasn't all there
800 isnt too shabby of a price and it saves on popping holes in the long run. i was quoted 1100 for dart sleeves but after doing some reading ive heard that some shoddy shops had been doing the job and after the engine had ran a little bit the sleeves "dropped". so im thinking aebs probably.
civicjdmb16a
thats what happened to my last engine with darton sleeves and i keeped blowing the head gasket :(
i would only have golden eagle themselves or Z10 do my sleeves this time. i know that they are reputable
civicjdmb16a
Got some new pics for everyone :D
Here is my head when i got it....still haven't taken it out of the wrapping yet.
Heres my valve cover. Its painted graphite with two fittings welded in for a breather setup
Here are my nice new pistons. They are Wiseco -18cc dish's and Eagle H beam rods
Here you can see my Z10 girdle installed with ARP main studs
Its all being assembled by this upcoming week and i keep everyone updated on my progress. :)
Visit http://www.xenocron.com :thumbup:
Post by classictuners »
looks like you're going to have one hell of an engine :thumbup:
Are you using the same turbo set-up from the old motor? With this motor, it seems like you can go bigger :shock:
Can't wait to see it in the car...
Where did you get the breathers welded into the valve cover?
civicjdmb16a
Yeah for the most part it will be the same. I really never reached the full potential of my last setup so i will try again with a much better platform. I do plan on getting a set of skunk2 pro 1 cams. Chris from Xenocron had my head built for these cams and says they respond very well to a high boost application. He plans on making 600whp at 24psi with this setup. I can always get a better turbo to make even more power, but for now i will make do with what i have. Chris from xenocron also welded those bungs in for me and then i had it painted.
I also ordered my limited slip from quaife today :thumbup:
"civicjdmb16a" wrote:I also ordered my limited slip from quaife today :thumbup:
I'm getting a Quaife installed when i send my tranny to Gearspeed. Should be within a couple of months.
civicjdmb16a
Nice which package did you get from them?
