Cougar289's D15B2 build thread! 56k DEATH!
So I've kept this project under wraps for awhile, so tonight I've decided to make a thread to show off my D15 Beast.
SEE BUILD AT: http://enginemaniac.blogspot.com
-cougar289
therealani
Re: Cougar289's cheap D15B7 build thread! 56k DEATH!
Post by therealani »
very nice!
I'm a little confused though ???
does the d16z6 intake manifold bolt onto the d15 head?
89 DX sedan:
-Si tranny
-CRX swirlies (rattled black)
-rear DA sway bar
-removed p/s and A/C
http://www.civic4g.com/forum/index.php/topic,9489.0.html
Sure does, it's the best flowing out of the sohc D manifolds imo. Much better than the b7/a6 manifold.
kerzaz
Post by kerzaz »
cougar289 wrote:Sure does, it's the best flowing out of the sohc D manifolds imo. Much better than the b7/a6 manifold.
were is diference between z6 and a6 manifold?
1993 nissan s13 200sx
1991 crx d16a6/d16z6 mini-me sold
1989 civic d16a6/d16z6 mini-me sold in parts
i dont think there is a difference.
1991 D16A6 Mini-Me OBD1...TURBO
kerzaz
Post by kerzaz »
me too but i have read that there is difference and z6 are better then a6
Throttle body is bigger on the z6, runners are also bigger and shorter. The b7 manifold is the same as the a6 manifold, it just doesn't say pgm-fi.
therealani
that's pretty cool! are there size/fitting differences between OBDI and non OBD injectors?
89 DX sedan:
-Si tranny
-rear DA sway bar
Nope, the OBD-0 injectors go right into the z6 manifold with the z6 fuel rail too. I'm currently running an OBD-0 setup, the only thing you need to do is plug the map sensor in and run a hose to the vacuum port for the purge solenoid. On a 4g the map sensor is on the firewall, on a z6 manifold it is on the top of the throttle body. The plug is exactly the same and no mods are required.
Looks good, remember to take it to a dyno when you have it together and you've driven it in. ;)
Re: Cougar289's cheap D15B2 build thread! 56k DEATH!
i gave you some karma cuz thats good info.
now im on the lookout for a z6, plus it gets rid of the big map sensor on the firewall 8)
Nice, original and budget friendly build. For the obx exhaust, did you get it on ebay? sounds too loud?
Yeah got the exhaust off ebay and it isn't really that loud, even with no cat. It really only gets loud over 5k, but from idle to about 4k its really mellow sounding. I replaced the cat with a resonator, and as you can see in the pics there's also another resonator in the mid pipe. It's one of the better sounded exhausts I've heard on a civic.
[img width=589 height=480]http://photos-f.ak.fbcdn.net/hphotos-ak-snc1/hs021.snc1/3054_65061037098_755702098_1758317_366199_n.jpg[/img]
There's a pic of the inside of the test pipe, not just a hollow tube.
Btw my current setup on the D15B7 is cai, z6 manifold, header, catback, cam gear, and pg7 ecu. Stock head, compression, and cam. It will outrun 92 - 96 integra gsr's, and nearly run with b16 swapped crx's. Both with i/h/e. Once I get my balanced D15B2 and si transmission swapped in, I expect it to outrun b16 swapped civics/crx's without much difficulty.
Upcoming mods: Balanced crank, rods, and pistons, Delta cams .400in lift 260 dur, block decked .010in compression 11:1, and .5mm overbore.
Dave
Post by Dave »
i love to see quick d15's, its proof that the designers got it right (and it allot cheaper than a swap)
Honda, the power of dreams.................. HONDA, the dream of power
Check this thread out if anyone is interested in more differences between the z6 and a6 intake manifolds: http://www.d-series.org/forums/naturall ... ifold.html
