Honda service bulletin relating to charging system
Don't know if this has been posted before but here's a bulletin that was published by honda to all 88-91 civics to help troubleshoot problems in the charging system be alternator, ELD, wiring, etc.
Voltage fluctuation, battery light on, battery not being charged correctly can be some of the common problems that can be diagnosed for possible causes using this bulletin.
Re: Honda service bulletin relating to charging system
does this count for our chassis or motors? not sure if swapped guys have to worry bout this since different motor= different alternator but then again this can be a chassis problem
These bulletins assume stock engines, if you swapped to a obd1 engine or a different series it doesn't. However if you stay obd0 with another d series it may apply. It's more for troubleshooting common electrical problems related to the charging system.
oo ok sweet! im a odb0 B so no worries here.... i think
good stuff jelly that archive of links you have is great
I also put this on the index thread so it doesn't get lost.
