88 - 89 cluster swap into a 91.
Northwesteclipse
Post by Northwesteclipse »
So I went to the junkyard today and was directed to a 88 - 89 civic sedan lx. (One of the employees told me it was a 91, but it isn't.) I pulled the cluster out and was planning on swapping it into my 91 dx sedan. But it isn't plug and play. Can I make it work in my car?
Re: 88 - 89 cluster swap into a 91.
I know it has been done, but have never seen it.
Besides that the face shape is different and won't fit right anyway.
(I'm pretty sure the Hoods are different, but not sure if they are interchangeable)
keep your eye out for a 90-91 they are out there ;)
The cluster will fit the problem is the plugs, if you want and can then cut the wires and start to wire them directly to the panel without the plugs soldering them....but guess what will happen if you need to change it ::)
Northwesteclipse
I was wondering if I took the harnesses out of the 88 - 89 civic, could I just wire those harnesses into what I got and plug it in?
no you cant do that. cabin harnesses have even the slightest difference.
think of it this way..... if it wont plug into your harness, how will putting a 88-89 harness on the cluster plug into your 90 or 91 dash harness??
Tursaanpoika
Post by Tursaanpoika »
Here are them pinouts:
compare the connectors and rewire as needed.
Images I found somewhere online, on another honda site, but cannot really remember where. Thanks to whoever made them:)
Good info tursaan.
Northwesteclipse
Thanks Tursaan. I appreciate it.
Probably going to see if I can get it to work this saturday.
