I have a small problem. My injectors are OBD0 and my harness I had made is OBD1.
I understand electrically this can work just the injector has a 2 small portions of plastic in the corners which will not allow the OBD1 connectors to slide on.
I was thinking of using my dremel to remove this small amount of plastic from the corners of the injectors so the connectors can slip on.
Anyone every dealt with this
I have pictures but don't have time to F with trying to upload them.
Thanks
